SR MAP Sensor?
MRNA
Car: '99 Maxima, '84 Porsche 944
Anyone know where I can find a MAPS for my SR?
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
umm map sensor? or mas sensor...map sensor is a manifold absolute pressure sensor an a mas sensor is a mass air flow sensor...map sensors arent found on SR's only mass air flow sensors. if you do have a MAP sensor please post a pic of it . perhaps its something that was added to the car,either way its prob something we need to take a look at.
MRNA
I know what MAPS are, and no I don't have them dummy or I wouldn't ask where I could get them.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The SR20DET does not use a MAP sensor so good luck in finding one.
theother1wstolen
Car: 92 240sx Coupe SE
i think what hes saying is he wants to get rid of the MAF and go with a MAP. I don't have an sr so I don't know, just thought I'd put in my two cents as to what he was asking.
MRNA
Ok, see the point of my post is not that I'm looking for an OEM part but exactly the opposite, I NEED AN AFTERMARKET MANIFOLD ABSOLUTE PRESSURE SENSOR FOR USE ON AN SR20DE WITH ITBS(INDIVIDUAL THROTTLE BODIES)!!!!
S14-NEO
like i said earlier we dont know your setup cause you failed to inform us..dont get the negative attitude cause that will never help you. if you really are just looking for a standard map sensor then just go and get a GM aka general motors one...make sure you can get ahold of the pigtail too. just in case you were wondering cause nobody in here thinks your a (dummy) they usually are a 2.0 bar map sensor.
Modified by S14-NEO at 4:48 AM 2/2/2008
