BlalockStevens wrote:Did anyone confirm/deny if the KA24E .adr and .bin's will work for the DE? Also, does anyone know what the difference is between the bins for OBD1 and OBD2 DE's?
I found these by viewing the KA24E ADR file as a word pad document. Then typed the addys (one by one) into my hex editor that came with my programmer. Had both the DE and E stock bin files side by side when comparing.
All of them look the same except:
High/Low Timing
High timing map for the DE is located 0D00, where as the KA24E is located at 0C00
Regular timing is same addy as the KA24E....0800.
VQ looks the same, in terms of high to low patern, it just uses different values.
K? I have no idea
TP Fuel: Same just different/higher values, follows the same pattern though
TP Fire: same as above
RPM Fuel: SameRPM Fire: Same pattern, but, substantially higher numbers
TTP MAX: SameTTP MIN: Same
Accel increas Vol: Same
REV and Max Speed: Not sure, Ill compare my stock DE bin to a well known tuned bin that I have later. Im sure they altered both of these values, just have to find thme....Ill check the tuned DE bin against the KA24E's stock values also. Ill keep you posted.
EDIT: Dont take this as 100% correct. As soon as I have time, Ill test it out on my DE. Still waiting on my 74H00's and gun to arrive.
