SR issues NICOCLUB GURUS PLEASE HELP!
playastarkz123
Car: 1989 180sx
Ok so the problem i am having with my car occurs ONLY when am under 2K rpms and on partially on the throttle. During this situation the car bogs really bad, i can even hold the pedal still at partial throttle and watch the rpms stumble until the car the stalls. My safc also reads 0% during this situation but it reads 0-100% just fine.
Its hard to describe my problem exactly by typing but hopefully someone has had a similar issue and come give me some solutions
BTW
I have already searched forums diligently
i have already swapped the TPS and the same thing happens
also my car seems to break up around 6.5k rpms as though i am hitting the rev limiter, even I know my rev limit should be around 7.5k rpms
my mods are z32 maf, safc neo, FMIC, and exhaust
key points:
-problem only occurs under partial throttle
-only under 2k rpms
-swapped TPS (and checked the voltages)
-car drives fine other than this issue
-breaks up around 6.5k rpms (feels like a cut as if i hit the rev limit)
-safc reads 0% throttle when partially on throttle
any help is appreciated thanks!
