exhsturbine »
https://forums.nicoclub.com/exhsturbine-u98723.html
Fri Sep 05, 2008 8:32 am
thanks for serving for this country, i joined the marines not too long ago and i appreciate what all other soldiers have done before me.
anyways....... too much fuel will not cause over heating. take a harley davidson for instance, its an air cooled engine, if you were to sit in traffic in a hundred degree weather, and the bike is gettin hot, the new bikes will actually inject more fuel to cool the engine down. all theory considered if the mixture is off anyways, the combustion wouldnt be as optimal = creating less fire, less heat other than friction but too much fuel would serve as "some" sort of lubrication.unfortunately your a million miles away and you cannot check your set up, so there about 30 different things that could have happened. i suppose ill ask the obvious, was the ecu temp sensor change from jdm to usdm? also, what is your setup? koyo radiator? oem? clutch fan? cooling panels? does the heater work? where do you live?
again thanks for serving....Miles
