the_invisible »
https://forums.nicoclub.com/the-invisible-u5272.html
Sun Mar 02, 2003 4:17 pm
upgrade Struts, springs, bushings, sway bars, should be replaced if they are not in good condition. tie rod ends should be replaced if it has torn boots.
If you are doing the 5 lug conversion, you are replacing the bearing as well since the 5 lug hub comes with new bushings. Spindles, all those will be replaced anyways.
if suspension arms are straight use them, if they are bent, replace them. Also, you should repalce the T/C rod.
brake lines, rotors, pads, new or rebuilt calipers. lube the caliper pins with lithium grease.
don't forget to take out the wheels and give the suspension arms a good scrub. I scrubbed mine with an old tooth brush and degreaser. Man, I swear it looks brand new. Also, use car washing detergent and water to clean the wheel well. It definetly needs some cleaning. It will look really nice after the job. There are lots of things to clean. They look old and rusty, but after cleaning them, they will look new again.
