Sr in an 89..help
SRpiccalo
Car: my car
i've put the sr in without power steering or ac so i have many plugs that are unplugged the only real trouble i'm having is locating where the ignitor goes on the harness and what plug goes into my mafs there are no plugs on the harness i got from phase2 that match up...help please
S13240
The ignitor chip plugs are orange inside and gray outside(ignitor chip plugs located on the sr engine harness on the intake manifold side if you had it routed through the passenger side like the stock KA harness.
Your maf plug is a bit short so you will need to lengthen it to reach all the way to the driver side if you routed the harness from the passenger side like the stock ka harness. You should be able to find it near the battery area...just get your maf and start matching plugs around that area...I'm sure you'll find it.
Also don't forget to hook up the oil pressure plug near the oil filter. I forgot to plug that one up when I finished my swap and my oil light wouldn't light up.
SRpiccalo
Car: my car
thanks
