skaterfromvt »
https://forums.nicoclub.com/skaterfromvt-u85054.html
Thu Oct 16, 2008 12:32 am
search and found problem but not solutions
sr20det black top
Ka24 sohc Mas airflow (have cleaned)
tuned ecu (62) can not check codes cuz red LED stays on
Was driving down the road and around 2800 rpms car broke up after that now car wont hold boost (checked for boost leaks) have not found any
when i pull a vacuum line off it sounds better at first but when under load breaks up...
Idle revs around 800 then goes to 1200 and back to 800...
I unplugged my tps the other day when i was working on the car and i drove around with it off and then when i plugged it back in and changed spark plugs and now its fuel rich and the idle goes everywhere...pulled plugs and replaced them with the old plugs that were working fine before i replaced them...and did no fix problem
cleaned mas, changed plugs, tried to check ecu, I know others have had this problem but there was no solution
need help*
