S13FASTBACKSR »
https://forums.nicoclub.com/s13fastbacksr-u34823.html
Thu Feb 15, 2007 7:40 am
first of all no, running rich does not cause bad idle. you can have richness and good idle or the perfect a/f ratio and bad idle or both richness and bad idle at the same time...second of all are you telling us you are running rich, or are you telling us the only problem you have is bad idle? if all you have is a bad idle then clean your iacv with carb cleaner by taking the idle adjustment screw out and spraying it in there...also take an air compressor and use the hose to shoot air in there..then put the screw back in start the car up and adjust the screw to see if that helps..if that doesnt help then make sure your timing is at 15degrees btdc.
