SR Idle Problem
RaulThinks
I have the blacktop Sr20. I did the swap myself, but I ran into a problem. I got the SR to turn on.The thing is I have to keep moving the throttle up and down so it wont turn off, but once I let go off throttle it turns off. Timing is correct were it suppose to be. I have all the grounds connected right. So far I've havent had no luck getting the info I need. I did search first, but couldnt come up with something related to my problem. I would really appreciate it for the help.
Thanks,Raul
Chicagos13
Car: 1992 240sx Fastback
Does it run after it warms up? I have this problem (for about 2 years). I usually give it a little gas on start up though, and it runs by itself. If I don't then it dies. If I catch it before it dies though and keep my foot on the gas to keep it idling, it will run by itself after a minute or two when it's warmed up a bit. I've heard it could be a problem with the AIC. Try some carb cleaner on it and see if that helps at all. This has been my experience and I'm not sure if this helps, but worth a shot.
RaulThinks
It turns off even if its warm. Once I let go off the throttle it turns off.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
does it run rich lots of black smoke or is it running normalsecond it could be the AIC or the TPS even the MAFtest them and see
RaulThinks
when i play around with the cas i can get the car to idel fine but the slots and the holes won't line up. i tryed for hours to line it up but it won't.The reson i think it idels maybe i'd advance it.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Your off a tooth on your CAS. I had the same problem, barely ran with the CAS cranked all the way to the end of the slot. I moved it a tooth (cant remember which direction mine required), set it where it was before I disassembled the motor, and it ran great.
RaulThinks
i'll try it
