JimLecesse »
https://forums.nicoclub.com/jimlecesse-u6791.html
Wed Nov 17, 2004 9:37 am
ive been messing with the throttle cable and adjusting the idle any way i can.. right now the idle is around 1100 rpm, and sometimes it jumps from like 1300 to almost 2000 (which seems to me like a vacuum leak)..
I'd be fine with a 1000 rpm idle, but heres the problem. at anything under 1000rpm the car idles somewhat violently.. the motor shakes and it sounds like its about to stall.. when I rev it it revs up fine, and when I drive the car theres plenty of power and its perfectly smooth at WOT.. but on the road if I let off the gas to cruise, (off boost) the car surges and runs very poorly.. as soon as I'm back on the gas its fine again.
