SR IACV (AAC) (Not your average problem)
Hurricane
Car: 1993 240sx SE
Okay, So since I got my SR I have never been able to get it to idle right. I have finally narrowed down the problem, and boy does it have me stumped. So hopefully some of the more experienced SR owners on here can give me some helpful information. So here goes.
The problem is with my IACV (As if you couldn't have figured that out from the topic) Anyways here is a list of what I've tried so far.
I took the IACV off over the winter cleaned/rebuilt it and resealed it onto the intake collector. I start the car let the ECU come out of cold start (the RPM's drop from 1300 to about 850) Blip the throttle and when the revs come down the motor stumbles and almost stalls. So the problem with my IACV wasn't fixed with a clean/rebuild. I also re-wired / checked my harness over the winter so I know its fine but just for my own sanity I unplug the IACV and do a continuity test on the signal wire to the ECU (sky blue) it checks out fine. Then I proceed to check the +12 wire (black w/yellow strip) also checks out fine. So the wiring is good. Next I decide to see if the AAC solenoid is still working. I hook up +12 to the AAC and ground out the other side to the grounds on the intake manifold. The idle goes up on the motor so I know the valve just opened and its working.
(I know it’s getting long bare with me!)
Okay my next though is maybe the +12 for the AAC is bad even though it’s giving me a good reading. So I hook up the AAC again this time using the +12 from the harness (Black w / yellow strip) again idle goes up so it’s working. Next I decide to hook up a new wire from the ECU to the AAC for the ECU Signal (sky blue in the harness) I blip the throttle a couple times. Engine still stumbles WTF. I hook up my meter to the harness connector blip the throttle again, nothing no voltage spike or anything. Now I KNOW the +12 is good so it must be the ECU signal wire which should be grounding out in pulses to open and close the AAC to control the idle. Alas its not.
So now I'm stumped! Heres my conclusions from my tests
The Valve works because when I apply voltage, the AAC opens the valve.
The harness is good I did a continuity test and also tried hooking up new wires / +12 sources and it didn't help at all
My next thought is well it must be the ECU. It’s a Blacktop SR with an E5 ECU. The harness was originally for a J4 but I repined it for an E5. So maybe I got the IACV pin wrong. EVERY S13 SR Source I can find says it should be in pin #113. Which it is. So its pinned right. I also found a couple places that said #115 was AAC so I did a ground test on pin #115 to see if it was pulsing a ground signal, its not. So I hooked the IACV up to pin #115 just for a lack of other options, as I though it didn't work.
SO
Either my pin # no the ECU is wrong (if someone with an E5 ECU could see where there sky blue wire is going and let me know that would be awesome!)
Or for some reason my ECU isn't sending out an IACV signal. Now I'm not sure if there is something that needs to trigger the ecu to send an IACV signal other then the RPM's being below 1000 or what.
Any and all help on this is GREATLY appreciated! Heel toe blipping at every stop is getting annoying just to make sure she doesn't stall on me... but on the bright side I am not the master of the bump start.
I have also tried blocking off every vacuum line (except the one to the FPR) and plated off the bov so I KNOW its the IACV causing the idle problems
S13240
A major boost leak causes the same symptom. But if it's not that...good luck, I already have a headache reading the issue.
