Tai Mai Shu »
https://forums.nicoclub.com/tai-mai-shu-u544.html
Sat Jun 14, 2003 5:56 am
no, Stock fuse works for me, but I blew 2 because I had the fuel lines swiched around, make sure you did not make the same mistake, the fuel pressure regualor is on the RETURN LINE to the tank, not the one comming outta the fuel filter. If so you might be over straining your pump cause it to blow fuses. You do not want a spark to go off in your gas tank.
