SR HELP please (I have searched)
Amigo1107
I have an s13 redtop sr and an 89 240. I have a ka radiator but the mechanic i'm workin with, who did the wiring, thinks my engine will overheat with just the KA radiator.so i wanted to get an SR radiator but i can't seem to find one for the s13.
So my question is, what differences, if any, are there between the stock s14 SR radiator and the stock S13 SR radiator??? can i install an s14 sr radiator into an s13 with redtop???
I apologize if this is a noob question to people but I've searched and found no good answer.
please help me as soon as you can cause this is one of the big things keeping my car from running.
thanks in advance.
Andrew "Breezy"
Titanium
Should tell us where you're located. If in the desert area then yes you'll most likely overheat. If in the colder areas where it does not reach 100 degrees or above then you won't have a problem with a ka radiator. s14 radiator will fit but with a bit of modification to the upper radiator mount.
Henry G
Your going to spend all this money on doing the SR swap, and cut corners by trying to use the KA? Nice....
Protect your investment and get a Koyo copper. If you could afford the SR, you have $160+/- for a good quality rad.
SmithSR
Car: 240sx
Henry G, I havn't kept up with the forum.. Which was decided to be better for cooling? The Koyo copper or aluminium?
SR20DETpwr
Car: 1992 240sx SE w/ built sr20det redtop
motor built by Stewart Engines LLC
put together and tuned by ILL Garage
.86 GT2871R @18.5psi = 393.4whp
Well as he said the radiator is $160 +/- ..... for that price I would assume it would be a copper radiator
If I were you I would spend the $305 on an s13 sr20det Koyo aluminum radiator ---- can buy this radiator from phase2motortrend.com, enjukuracing.com, heavythrottle.com (I'm sure there are others I just can't think of any at the moment. The stock lower radiator hose for the USDM 240sx will fit the sr20det w/ koyo aluminum radiator (you'll just have to trim the hose a little where it connects to the engine). For the upper radiator hose you'll need to buy one of the flexible ones from the autoparts store until you can get the OEM sr20det one (or some nice silicon ones) --- again, available from one of the above mentioned shops.
SpeedRacer1
Car: 1990 240SX, G35
S14 radiators will work in S13's, the upper mounts just wont line up.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
I live in New mexico and in the summer it gets well above 100.And on my friends 89 240sx we did the s13 swap and he used the ka24e radiator and he hasnt overheated once.Is the sr20det radiator bigger then the ka?I use the radiator that came on my s13 silvia front clip.And it dosnt look any bigger.
tubakins
Car: 89 240sx fastback
REDLINE WATER WETTER!!!!! get some it will decreace use temp by 10-20 degrees. it should help if u cant afford the rad. also look into a low temp thermastat
Amigo1107
thanks guys, i appreciate the help.
Henry G wrote: Protect your investment and get a Koyo copper. If you could afford the SR, you have $160+/- for a good quality rad.
but where can you get a koyo for 160..??? the only price i can find them for is like 290 - 320. if i can get a coyo copper for 160 i'd do it. it was the 300 that was worrying me. just to be sure, copper cools almost as well as Aluminum right...?
Titanium wrote:Should tell us where you're located.
and I'm on the Tennessee/Georgia Border.
tubakins wrote:REDLINE WATER WETTER!!!!! get some it will decreace use temp by 10-20 degrees. it should help if u cant afford the rad. also look into a low temp thermastat
redline water? never heard of it 'till now. thanks. Is there a certain thermostat you reccommend?
thanks for all the quick replies and the help. you guys rock.
912.0turbo
SmithSR wrote:Henry G, I havn't kept up with the forum.. Which was decided to be better for cooling? The Koyo copper or aluminium?
The Koyo Copper.
kota2240
Car: 92 Nissan Coupe W/ CA18ddet
the koyo aluminum is better then the copper. The copper is the same size as the ka and sr, it just has a better core.
So going from worst to bestka rad, koyo copper, koyo aluminum, greddy lol If you find a sr rad then use the clutch fan and fan shroud from the sr. you should never have problems then.
912.0turbo
Sorry but you are wrong Kota. I live here in Texas where it does get over 100 degrees. There is a thread on FA where two guys from here conducted a test on 4 radiators using datalog equipment. They drove around for a few days gathering info such as temperature with each radiator and found that the Koyo aluminum ( which is the one I have BTW) was pretty close to stock when it comes down to it. They also tested a dual pass and the Koyo copper. The test results went like this:1. Dual pass2. Koyo copper3. Koyo alum.4. Stock
USsil80
dual pass??? mybe i am being stupid but explain please
912.0turbo
USsil80
that thing is nasty...i want one
912.0turbo
So do I.....(sigh)
USsil80
i looked on there site but didn't see a price...knw what they go for...
tubakins
nismo low temp thermostat
912.0turbo
USsil80 wrote:i looked on there site but didn't see a price...knw what they go for...
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
ok if the RB motors can use the stock ka radiators than the sr can to but you might check your themostat or water pump just a suggestion
