SR has no compression
BoostedPig
Car: 1990 s13 pignose Sr20det swap
I just recently replaced my head gasket and front cover in my SR and put it back in today
It wont start.....
Turns over finehas sparkhas fuelbut.....has no compression
around 30 in cyl 1 and below 15 in 2,3,4
Timing is correct and Rings are good....I have no clue why I would have no compression....
Any ideas??
480sx
Car: 1996 Pearl White 240sx
Cam timing maybe, idk.
BoostedPig
cam timing is good!
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
I would recommend re checking your cam timing, and while you have the valve cover off check and see if you seem to have a noticeable amount of clearance between the rocker arm in the cam when the cam lobe is pointing up, you may have had the misfortune of bending some valves.
Sileighty_85
Car: 1991 180SX
Did you machine the head?If not then your head is warped and needs to be machined
ars13
Car: 89 240sx
There's a local sr guy here that had the same problem... His problem was the head lifted cause the stock head bolts expanded too much. Did you replace them? I doubt that could be what it is but it's something eliminate from the list of possibilities.
ZakinaS13
Car: 90 S13 w/ 98KADE
It has to be the head bolts, you used the old head bolts and torqued them down to stock specs. Replace them and you will be fine. After X amount of miles, those bolts really do stretch.
