kord57 »
https://forums.nicoclub.com/kord57-u30283.html
Thu Feb 08, 2007 7:18 am
from what i understand to set the timing you align the crank pulley to the yellow mark(second from the farthest left) then line up the CAS with the right mark on the shaft and the mark on top? if this is the way it's done then it should be correct? I'll recheck all the plugs inside the car to make sure they're plugged in all the way. The check engine light isnt coming on but can i still check for codes or do i have to use a diagnostic tool on the s14?
