Hi all
I have mounted an S14 SR20DET Engine into my enginebay and everything is ready to go Except the Harness. **** this is so hard to get to work!!
I got the engine to the Right on this pic: (S14 Notchtop)
Problems:All help info I've found has been TOTALY waste of time. Since it seems like most of you ppl use some sort of other SR engine (the SR S13 version, the middle one on the pic) and that one connects perfectly to the instruments and everything with some very small modifications. This in other hand has one hell of alot more connectors and stuff on. How do I get this to work!?
I assume that those of you who actually got this to work will understand the problem.. the harness info and details I've found has been for a totaly diffrent ECU and harness and such things (the S13 SR one...).. I need help!!
I don't want to proceed until I know for sure how to do this.
