pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sun Feb 13, 2005 3:21 pm
If you are thinking the SR harness is gonna be a direct plug on thing, that won't be happening.
Yes the SR and the Ca share most of the same sensors, but few sensors are different and won't plug in. The sensors that are shared with both engines are located in different places on the engines, so you will definitely have to extract the wiring from the SR to reroute them to work with the Ca sensors due to their location.For example, the CAS sensor plug on the CA is completely different, as well as the ignitor plugs, unless you use an sr ignitor and good luck finding these as they could be pricey.Also, the injectors plugs are keyed differently.The ecu plug will plug on the CA ecu, but I am pretty sure the Blue plug for ecu on the SR has different pin out locations.
The bottom line, yes you can make it work but it will cause you tons of time and you have to cut plugs of the SR harness and replace them with plugs that will work on the Ca.To be honest with you, it will be easier to extend the cut harness and fix it than going though the SR route, all what you have to do is match the wiring colors.
Not sure if any one here might have one to sell you.
Good luck,PULSAR GTRRafi
