SR HARNESS HELP
drftsx
Car: 90 240sx(sr)
I was wondering how many grounds are there in the SR harness, excluding the ground that is attatched to the ignition coil harness.
How about the lower harness?
i had a shop do my harness, trying to see if there is anythin wrong with it.
I have a J4 ecu. im thinkin the shop might have wired my harness to the older blacktop ecu.
Blown240sx
Car: 1996 240sx
Altenator GroundCoil Pack GroundBlock Groundand maybe 1 other one
Im not sure if the ECU has to be bolted down for a ground or if it has sperate ground wires located behind the ECU.
xero1
Car: 08 Altima Coupe
there should be another ground wire that grounds to the body.
