Thanks for the reply, I haven't touched the timing nor do not know how to check it but I will look into it. Throttle position sensor (tps) looks clean, other than that, I don't know if its faulty. I guess it would be pretty obvious when I'm driving if its bad right?nismostate wrote:check timing? tps?
I'm not sure if the sensor is bad and don't know how to check it but will look into it. Thanks. Can you also advise on how it may affect starting problems? I'm just curious.Silvia007 wrote:I'd replace the water temp sensor for the ecu, not the one for the gauge.
This looks pretty promising. I will look into the orange wire going to the dash from the ecu. The link was pretty confusing but I'm pretty sure thats what it is saying right? I hope this is it but I will update this post to let others know how to deal with this seemingly common problem. Thanks for the help guys.PhopsonNY wrote:I had this proble with cold starts and discovered my ECU had not been screwed down tight so the Orneg wire as outlined below was not making good contact.
Tightened the ECU down and have had no problems since.
Thanks! I never knew . . . I'll be sure to check it out. I think its running a bit rich too, so that could be it. I didn't mention but I don't have remote start. I just sit in my car and look like an *** until my car starts, which I don't mind until old ladies ask me if I need help.Silvia007 wrote:The water temp sensor tells your ecu if the engine is cold or hot. Depending on which, it'll add or reduce the amount of fuel to optimize the cars starting ability. When it's not hooked up, you can start your car but once it warms up and you turn it off, you can't restart it till the engine cools down (because your car thinks your engine is cold and is sending the wrong amount of fuel for startup so your engine will just turn and turn like if you were to have no fuel or spark). When it goes bad, it can do what was described or it'll be difficult to start when cold but fine when warm. It uses resistance to determine if the engine is hot or cold so depending on when it's damanged it'll stay at that resistance which in turn tells your ecu what the engine is "supposedly at" sending the wrong amount of fuel which will definately affect starting.
