pgt892 »
https://forums.nicoclub.com/pgt892-u2513.html
Thu Apr 28, 2005 5:37 am
If you didn't replace the stock fuel pump with a bigger unit, then the car generally won't run rich unless the computer senses a problem. Pull the codes from your ECU. If it senses a problem, it can run in limp mode and cause the car to run rich. Also, if the O2 sensor you are using is old and sending irregular signals, the car will run rich. Also, SRs run rich stock.
