Sr guy wanting to RB
thes14project
Car: Thinking my friend and I have mechanical skills
I just sold my 98 Sr powered 240, and for my next project I am looking into RB25 power
I got $7000 for the engine I'd like to be able to get the folowing done to it
motor set, Downpipe, Exhaust, FMIC, Bov, Radiator, fans, clutch, wiring, turbo timer, gauges, boost controller, fuel pump, mounts.
Anything else I need?
Can you guys point me to some install threads? Fitment and what not.what about HP upgrades. Basically an RB guide for dummies
Thanks, Scott :withstup
(and I thought I was past this)
Joe
just search man, all of this has been covered countless times.
most of the info you need will be in the stickied threads at the top of the forum.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
thes14project wrote:I just sold my 98 Sr powered 240, and for my next project I am looking into RB25 power
Yeah do a search on the forum and all will be clear cept for the HP one. 60-1/T3 356hp on stock injectors at 13psi of boost. He is selling his the turbo setup right now. Some other guy with standalone hit 533hp but killed a ring. Motor is been built or already is. Mckinney has all the stuff you need just Call em or Email em.
cyris3d
talked to him about the motor and setup allready
dekand
Car: 1995 240sx SE
yeah theres plenty of info out there... search before you contact any shops as well... it'll keep you out of trouble.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
yes, do yourself a huge favor and before you buy from any vendor, search their company name, google them.. etc..
Their are some really good guys and some really bad ones out their.
Check out Mckinneymotorsports.com. search my name and on here and you will find out about my swap and where I got everthing.
xjon
Car: 99XJ, 93 240coupe
I second or third about searching on vendors. And welcome also.
NISMO_RB25
I will throw out two recommendations for motors/clips:
I bought mine from http://www.dragdriftautox.com, and had no issues.
Also follow dekands banner, that is the cleanest clip I have ever seen. (he got it from RS Imports) You could eat off that clip!
xjon
wiring should come with the motorset and ecu also. don't forget driveshaft. It really depends on what your motorset comes with or what has gotten damaged.
possibly spark plugs, timing belts, h2o pump thermostat, etc. list could go on. it also depends on how much power you want at the end. For example, you have power mods but what about lsd? It is really an open ended question. look around here and you'll find a lot of helpful info. Good luck.
