Clawhammer »
https://forums.nicoclub.com/clawhammer-u53050.html
Thu Apr 23, 2009 11:31 am
...lay under my car and kick out a jackstand.
New years I blew my head gasket. I got an Apexi and some ARP studs and swapped it. Car ran for a couple hours, I drove it around my neighborhood a bunch of times and it was running funny. Seemed like a vaccum leak kind of.
It was idling at like -10inHg, and thus would spool into boost really quick. I'd be at a couple pounds by 1500 rpms and was surging the the entire time. I parked the car and went to work. Came home about 9 hours later and the car wouldn't start. It was getting fuel and spark, I did a cold compression test and it was 65 across the board.
Figured I screwed something up so we yanked the motor and rebuilt it. I also redid my harness. I also got a brand new head, well, freshly rebuilt with a couple thousand miles on max.
We finally dropped the motor back in and once again, it will not start. Same as before all this. Cranks to no end. I'm getting spark and fuel, but nothing. It just floods from all the cranking.
We did a compression test and got 90 across the board. About 3 weeks before I blew the HG I was 165, 165, 160, 165. We reset mechanical time and got compression back up, 160-150 across the cylinders. So timing was off. It fired once with the new compression but died instantly, never ran.
My ECU keeps throwing a code 13, we replaced the CTS and it's still doing it. replaced the sub harness to, still does it.
We swapped ignitors too, no help.
The gas has been in the tank since December 31st (I filled up the day before I blew it, awesome. I put stabil in it, but maybe bad gass that won't ignite?)
I'm pretty confident in my harness, especially since the problem hasn't changed. I also figure I'd be throwing a lot more codes if I screwed something up there. Even the CTS one has me confused, it's only 3 wires, well 2, the blue/black one is for the dash sensor. Anyway, I'm not ruling the harness out to not look like a failure, I'd much rather the car run, I just don't think that's the problem.
Any ideas? This is stressing me out big time and has got me pretty depressed lately. I miss the good old days when this piece of junk ran.
Ryan
