sr fuel question
jin3000
Car: my car, car mutimedia, custom speaker and custom interior design
is the stock 97 240sx fuel pump adaquate to be used on the sr motor at stock boost?and if so what is it safe up to ?is the walbro the most used brand for the ka/sr swap?
USsil80
the walbro is the most comman... it just drops in easy to do to any one that did there own swap.... y chance being ok on fuel.... but you should be ok on stock boost but i would upgrade it before anything else...
Fireplug
Car: '93 240sx (Built SR20, PT67)
I'm not sure that the KA fuel pump is adequate enough to boost on..even at stock boost levels. I'd play it safe and get a walbro in there! I remember back when I did my first SR swap...I was told the Walbro is a must! Now I'm running 2 walbros
USsil80
yea ... i did the same .. then sumped the stock tank and am running an external aeromotive fuel pump... with #8 fuel lines
