sr front cover
wannaS13
Car: 92 240sx
the front cover on my blacktop is cracked and leaks a small amount of oil. i can get a new pump/cover for 199 or just the cover for 59(i would switch in my pump). i have awesome oil pressure so i know the pump is good but what is everyones opinion on this
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
Just switch over your pump and save 140 dollars.
luv2spedup
Car: 89 silvia
i would just buy the whole thing, can t go wrong with a new oil pump
burntricer
Car: 90 S13 SR20DET Redtop
or do what i did. took mine in and got it tig'd for $20
lol
but yea, you have to pull your engine to change it huh?
wannaS13
Car: 92 240sx
im pulling it anyways to do the head gasket, studs and z transmission swap. im just thinking why not just switch pumps and save money
Hijacker
Car: '92 240sx Convertible
'94 F-150
The reason you may want to consider getting a whole new pump with the assembly is that if you buy a used cover minus pump, the new cover may not have as tight of tolerances as the old cover.
If you do decide to go with a used cover, double check the clearances. Any pump I've seen with issues, it's usually the tolerance of the pump gears themselves, but I'd rather be safe than sorry.
Sileighty_85
Car: 1991 180SX
Its cheaper here : http://www.thenismoshop.com/ik...d=284
You oil pump is about 17 years old by now if its never been replaced.
Buy a new one
