SR fluids
drftsx
Car: 90 240sx(sr)
im almost done with my sr swap and was wondering what kind of fluids i should be using.
what kind of: gear oil oil coolant thnx
Henry G
For engine oil you should use something cheap at first and change it after 500 miles. transmission fluid and coolant can be some good stuff.
For transmission fluid a lot of people like redline products.
ho1ywars
i dont know if this is the RIGHT stuff, but this is what i am running.
royal purple fully synthetic motor oil (5w30 this winter depending on oil pressure)
fram filter
mobile one fully synthetic gear oil in the crank and diff (i forget the weight)
preston coolant with redline water wetter
like i said, i dont know what your suppose to be running, but this is what i use.
vutony
fram filter = junk
oem is best for the price (92 ser)
redline mt gear oil
mobile one, royal purple, amsoil, 5w30 in the winter and 5w50 (somethin similar to that) in the summer
teddy
Car: Saab Turbo and MR2
ho1ywars wrote:mobile one fully synthetic gear oil in the crank and diff (i forget the weight)
Mobil 1 Syn Gear oil in the open diff = OK. Mobil 1 Syn Gear oil in your transmission = No No. The m1 syn is a GL-5 oil, whereas our transmissions need a GL-4 oil, because it's safe for our brass synchros. That's why most people use the Redline MT-90.
The fram filter is junk. Do yourself a favor and get anything else. You can use just about any generic coolant out there and it will do the job.
As far as a weight for oil, you could probably go many different ways with no problems. 5w30, 10w30, 10w40, 0w40. If it's really hot in your area, maybe a 15w50. Use the search button. There's plenty of oil related threads in this forum.
Rosco
Car: 91' SR'ed Hatch
Engine Mobil1 15w50 full Syn FTW!!! I have tried Redline and Royal Purple and Mobil1 seems to be the secret ingredient for SR's. Still want to try AMSOIL....I posted awile back about tests on different oils and AMSOIL was number one on all tests. OIL Filter Mobil1 (M1013...I think)FTW (are we noticing a trend here)!!!!transmission Went with Redline, but I am convinced it runs too hot (shift boot leather balloons up, will change and try Royal Purple soon), but it's not that bad, very smooth.VLSD Redline heavy duty shock proof mt-90, has been over 9 months since I swapped in a VLSD with the NISMO gearing (4.4:1). I am convinced that Redline is the greatest thing you can do for any Viscous LSD. Works exactly like an LSD should.
180fan
Car: 89 fastback
engine:motul 300v 15w-50
oil filter:oem
transmission:motul motylgear
diff:motul 90pa lsd oil
coolant:toyota red
vutony
180fan wrote:coolant:toyota red
nice, i have a spare bottle in my garage
drftsx
Car: 90 240sx(sr)
thnx alot u guyz thins is very helpful for me
deCksy
engine:neo synthetics 15w-50
oil filter:pureone purelator
transmission:mt90 or neo umm i forget weight
coolant:uhh just neo keep cool and water
kamikazestorm420
engine: mobil 1 15w-50 fully synthetic (i live in CA its HOT)
Transmission and Diff: Redline MT-90
coolant: any coolant will do ...
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
seems liek everyone running 15w50 is a cali guy
how would 15w50 fare in the PA winters?
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Engine - 10w30 Mobil One Full Synthetic. I used to use 15w50 but heard of a few people having oil pickup issues so i switched and been using 10w30 ever since.
Trans - Redline MTL
Rear - Kaaz Hypoid (Nismo 2 Way)
myees13
Car: 90 s13 coupe
Rosco wrote:OIL Filter Mobil1 (M1013...I think)
part # M1-103
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
I use
Royal Purple 10-30 in the engine with a OEM Nissan filter.In the transmission Redline MT-90 And the diff gets Redline oil too.
I also run Redline Waterwetter in the coolant and water mix.
aleph1
Car: 1990 240SX hatch MODS: class.
15w-50 does have pickup issues, my first SR developed rod knock due to this as I cannot think of any other way it could have happened. (Car was in cali then)
Now its in Colorado I run:
10w-40 Royal Purple in summer (can get hot here, hence the 40 instead of 30)5w-30 Royal Purple in winter (need the thinner oil for those cold starts)
OEM Nissan/Mobil 1/K&N oil filter...whatever is more available to me at the time.
Royal Purple 75w-90 for the transmission
Valvoline 75w-90 for the diff. (Open)
Im looking for something a little thicker for the transmission as its old and is starting to grind a little, how does MT-90 compare to RP? is there something more recommended for older trannys?
