FTRS14.5 »
https://forums.nicoclub.com/ftrs14-5-u3490.html
Fri Feb 27, 2004 5:39 am
If I were you, I would pull the whole thing out again and just send it to Heavy Throttle for the wiring service. You are guarenteed a turn key start (If all the other work has been completed correctly) and you wont' have all the headaches of trying to figure it all out, which I know you probably have a migraine by now :pface It's costs a bit more, but if you can afford I would definately do it. It'll provide you with that confidence that nothing will catch on fire, burn out, or blow because of the wiring that YOU did.
