D-UNIT wrote:Ever thought that the low pitched video cars are KA powered? Just kidding! maybe... From my experience it seems like low pitched sound comes from stock (small) turbos and low to medium low boost levels. But mainly stock turbos have tiny inlet and outlet holes which restrict sound levels causing low pitched/low turbo sounds. Whereas upgraded turbos are bigger in everyway , equaling more power at the the same boost levels. Therefore more spooling and turbine sounds are emitted causing a higher pitch. 7 psi vs 14 psi is technically double the air flow going in and out. Just imagine your typical house fan. At the low speed setting it sounds very low pitch and soft , but when you turn it to high , the pitch and decibels increase dramatically. And we all know those japanese SR's are hammers.
I'm now convinced that it's the cams that make the sound difference, because my friend with the cam'd t28 SR has the glorious high-pitch sound, whereas all my other friends with SR's have stock cams and t25/t28's, with all different types of manifolds/exhausts, yet all of them are low-pitch.
Kinda sucks, cause I'm not gonna get cams for my obsolete CA18, so no high pitch glory for me (until after college when I can build an SR).
