nismostate wrote:Man, Im really worried about this swap. I have a pretty good knowledge about how everything works but the electrical part worries me. I NEED a CAR!
Dont be worried about the swap, just buy the swap from heavythrottle and have them do your wiring for you and do not take the cas out unless its broken!!! I bought my engine from a friend of a friend in Texas that owns a shop down there, the engine itself is in perfect condition and compression tested 152across all 4 cold. The only problems i had was the rest of the parts, my wiring harness plug for the ecu was broken when i got it and a lot of the plugs on the harness were broken, and I had a dead injector i didnt find out about till I bought upgraded injectors. Also my cam angle sensor was bad when i got it and he sent me a new one to put in and im having a ***** of a time timing it. I also bought a brand new wiring harness and did the wiring myself to save the 100bucks which was a mistake.
