SR Downpipe on CA without SR Turbo Elbow/Extension
AppleSauce
Ha, thought I would finally make a post on here.
Do you have to have a SR turbo elbow/extension to be able to use the SR downpipe on a stock CA18DET ?? Also has anyone using both SR pieces had any clearence issues with the frame rail??
Thx!
Darius2250
Yes, if you try to use the CA elbow the flange bolts will be off about 30+ degrees
float_6969
You have to use the SR O2 pipe with the SR downpipe, otherwise the flange is oriented incorrectly and won't even come close to working.
