SR doesn't Run
ZOMG.SR20
Car: 1990 s13
1. where can i get a starter for the SR or can i rebuild it
2. when i got it to start the Revs would fluctuate between 200 and 500 and the throttle plate moving did nothing and im getting fuel and spark the highest it would go is 500rpm
any help is greatly appreciated and if anyone needs more info just ask and ill try to find the answer.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
1)If your motor set came with a starter than a starter off of a SOHC 240 (89-90) will fit. You just have to swap the guts.
2)Maybe bad MAF (mass air flow)?
ZOMG.SR20
Car: 1990 s13
i had a bad MAF on my other 240 and its not that
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
did you cjeck your timing?? I wouldve guessed mafs, but if your sure its good, double check your timing...Check your TPS as well as IACV
ZOMG.SR20
Car: 1990 s13
how do you check the TPS/IACV also does anyone have a wiring layout for the TPS for the plug what are the colors from one side to the other
Koshin
FSM friend...there is one posted on NICO...
ZOMG.SR20
Car: 1990 s13
FSM download in the FAQ doesn't work
Koshin
weird....
If you need something specific I can scan the pages and send them to you via email...LMK
Rich
try the FSM download on NICO again
