SrS13 »
https://forums.nicoclub.com/srs13-u7012.html
Fri Feb 27, 2004 10:04 pm
First off I've been having problems with setting the timing on my Sr20. I follow this procedure: let car warm up, drop rpms to 7500, unplug the TPS, then adjust timing using CAS. The problem is that after I set my timing and plug the TPS back in the timing jumps a couple of notches back or forth every time. What am I doing wrong? or what if something is wrong?
Also, My stock temperature gauge sensor has begun to opperate in a strange manner. It is surging constlantly. It will mark C when I floor it and when I am at idle it marks normal. I switched my sensors from my KA onto my SR so I know its not that. Would I just have air in my system?
I also noticed my top radiator hose gets hotter than my lower hose.
Please Help I desperately need technecal advice.THANKS :help :help
