there's a relay on the passenger side right next to your washer fluid with two connectors attached to it each has two female prongs to it. You jump the two prongs on the bigger connector. That will buypass the clutch sensor which will no longer require you to start the car with out pressing the clutch.bobbyhill wrote:I tried starting my SR the other day and when you turn the ignition to try to start it clicks and doesn't start. The starter checked out good at AutoZone. I checked all grounds, fuses under dash and underneath hood and everything seems to be good.the starter has 12 volts when you try to start the car. Is there any other switches or fuses that I need to check??? Thanks
I don't remember if it was blue. I don't have it anymore so I couldn't tell you but yeah, theres that relay next to the battery closer to the fender side, actually attached to the wall, has two connectors to it.homeslicej2 wrote:^you mean the blue relay beside the battery tray? I have something similar going on. I wonder if this is my issue.
