thx for the information!i actually have a SAFC II, but i think its not hooked up right. anyways, how to you set the SAFC to solve this problem then? thx!Blown240sx wrote:For some reason some SR swapped cars have no problem with the vented BOV and some like mine hate it. I solved it by getting a SAFC which has a setting to compensate for a vented BOV.
Ive also thought about routing my MAF to the cold pipe near the intake manifold so it never sees that vented air so the air calculation isnt thrown off.
i appreciated your help!OH AND MOD PLEASE MOVE THIS TO FAQ, IM SURE MANY PPL ARE LOOKING FOR THIS.. BLOWN240SX, U MIND IF I LINK THIS ON OTHER SITES?Blown240sx wrote:Its the Dec. Air setting. Read the instruction Manual and it will tell you how to set this feature up.Or if you dont have the manual you can get it on the Apexi Site.IN a nut shell you look at readings while the motor is still cold at different RPMS then you enter in numbers larger than those readings you get for Air Flow% and Throttle %. I think the RPMS you hold it at are 1000 at 1500
Just get the manual it exsplains it better than I can.
Thats because my car idles at like ... 1000 RPM.Blown240sx wrote:For some reason some SR swapped cars have no problem with the vented BOV and some like mine hate it. I solved it by getting a SAFC which has a setting to compensate for a vented BOV.
