Sr cutting out at about 2500 rpms...
zach-Ka
Car: 1990 240sx (SR)
Before I spend $120 on a new mafs I just wanted to make sure that a fried mafs would cause this? Any info would be most appreciated.
zach-Ka
Or could it be my TPS?
jetroy240
Car: S13, AE86
check for codes first.
johnnyballs180
Car: 1990 240sx
2500 seems to be the magic number for maf problems. you sure the plug is on there tightly? and it doesn't idle well, right?
Mr.toofotay
make sure none of your maf wires melted.
zach-Ka
Well I have a FWD sr mafs and im gonna try to wire it up today. I think I messed up my mafs when I hooked it up wrong and put the power to the signal and the signal to the power. i will check the wires all the way back to the ecu today. Thank you guys very much.
speedracermage
Car: 1989 nissan 240sx
i had the same problem with my sr when i did the swap and found that one of the wires on the maf was loose. i redid the connection and havent had a problem since.
s13silviasr20det
Car: 1990 240sx
MAF for sure...no doubt
