martin »
https://forums.nicoclub.com/martin-u2584.html
Sat Dec 20, 2003 1:17 pm
Just so you know, this probably isn't a problem. I've done a few installs, always check the compresison. Usually there's one, or even two, cyls that are low. The reason is that these motors sit for often long periods without running. The valves that are open tend to stick open (hence the hissing into the intake manifold).
What I do is make sure the oil pan is good, change the oil and filter. Hook up a mechanical gauge if you have one. Pull all the plugs and squirt 4 or 5 pumps of oil from an oil can into each cyl. put the plugs back in. Hook up a battery and crank it over for 30 seconds (not too long or you'll burn out the starter). Note turning it over by hand won't get the oil flying around, what you need to do is ge the oil to the valve stems and seats.
Now pull the plugs again and check the compression. I've had ones that were reading zero now read 120 just after doing this. Sometimes you need to repeat the process on the bad cyls.
Oh.. why change the oil and hook up the gauge? That's problem number 2 the loud tapping from the timing chain... this is because the oil pressure isn't up, and the timing chain tensioner isn't being pumped up. Repeat the 30 second cranking (with the plugs out) until you see pressure on the gauge... when you have pressure you should no longer have loud tapping.
Note... let the starter cool down for at least 5 minutes between 30 second cranking sessions.
Once you have oil pressure you should be able to see oil dripping from the spray bar onto the cam lobe when looking through the oil filler hole.
Redarding the compression... you probably won't see 150 across the board, but you should be able to get the bad cyls up to 120 or so. Once the motor has been run up to temp and cooled a couple of times then you should see even compression across the board.
-Martin.
