i just finished swapping the SR into my 93 coupe. when i first bumped the key the thing started up and idled beautifully. went and drove it, all went well, drove well, came back to idle well.
i got in the car the morning after i originally drove it, it was pretty cold out ~35 degrees and it just didn't really want to start. it would bump off here and there but never catch until after i've turned it over for a minute or two (short bursts). so i played a little and found that if i hold the throttle wide open and crank it about 2 times then bump the starter it will start after a few seconds and bring itself up to idle. after that the car runs great, it seems as if the cold start idle is working because it does initially idle high and drop down as it heats up, and during driving the idle drops back to ~850 as it should and everything about the engine when it's running is perfect. it just seems as though it's not getting the extra fuel at startup that it needs in colder weather, but i can't really figure out what controls that on this engine. i originally thought it was a bad coolant temp sensor, but the car runs perfect after it finally starts (i don't have the stock gauge working to confirm/deny this at the moment, i wired the wrong half of the plug onto my harness so i have 2 male plugs for those, but will be fixed very soon when i can go hack a KA harness at the junkyard). if the IACV were bad it shouldn't idle right when the engine is still cold but running, or at least that's my past experience with a problem like this. so i'm stumped
can anyone shed any light on this subject?
