ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Tue Nov 12, 2002 9:26 am
Is your check engine light on? Your O2 messed up? Thermostat? Ok, lets go over the "Four-Stroke 101". When an engine is started cold, it needs to run rich in order to keep going. Many cars use the water temperature to know to run rich or not. Many times, when a thermo or temp sensor is messed up, they either keep telling the engine is warm all the time which leads to poor cold starts, or they are telling the engine that its cold all the time and leads to high idles and very rich mixtures. The O2 plays a role in this also by "testing" the air mixture of the exhaust gas to determine if its lean or rich and tells the computer to add or take gas to the mixture compared to the condition the engine is in. Those are the main culprits of a rough cold start in most cases. Go check those out.
-GenX
