Sr cluth same as sohc?
sickniss
I had bought a new centerforce cluth for my 240 before i did the swap and i never put it in.. i was wondering if this is possible? the transmission looks the same
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Gearbox is the same, Bellhousing, flywheel and friction plate are different.
If its just the clutch disk your talking about, if it is the right diamiter and thickness I dont see why it wouldnt work, should fit on the transmission input shaft.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i believe they're different diameters. a stock SR clutch is the same as a stock maxima clutch
