sr clutch!
Acumo
Car: 92 hatch
hey guys i have an sr with a 8 month clutch!! it keeps making a squeeky noise everytime i step on the pedal.. everything is good gears everything but im worried about it!! if u know anything that could help feel free to post ty
Acumo
Car: 92 hatch
ANYONE?????
slow s13
Car: cars, photo, music
my stock one does the same thing dont worry about it
bgsr240
Car: 90 240sx hatch sr20det redtop gt28rs-sold 89 240sx hatch S14 sr20det blacktop
throwout bearing maybe?
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's throwout bearing if it's coming from the gearbox. It's just a squeaky pedal if it's coming from under the dash.
Typically, I've only heard TO bearings grind, not squeal. They get locked up with dust and bind up. Then they start to eat the fingers off the pressure plate.
If it's the pedal, there's a small plastic bushing for the return spring to sit in on the pedal arm. That bushing tends to break away and allow the spring to press directly into the arm, which in turn squeaks from the totally hot, totally wild metal on metal action. Spray some lube up in there and that will alleviate the problem, but not permanently. I find WD40 works mediocre, and a lubricant called HKS 2000 does a good job for a while (also does great at quieting squeaky door hinges)
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
mmm...I have a similiar problem except there is a squealing noise from under the hood/side of the car (more on Passenger's side) when I press the clutch pedal in about 1/2" (not enough to engage the clutch) it goes away. I don't know what it is. The Master and Slave cylinders are new (~7 months and 4-5k miles old) OEM parts.
Acumo
Car: 92 hatch
tenkawa_akito wrote:It's throwout bearing if it's coming from the gearbox. It's just a squeaky pedal if it's coming from under the dash.
wow awesome dude thanks alot!!
