SR CAS cover on KA distributor
Ruff Ryder 6
Car: 1990 240sx coupe, 1990 N/A 300zx
I know this seems like a weird question but all i need to know is if the cover from an SR20 CAS will fit correctly onto a KA distributor. If so i'd like to grab one of the clear ones i see for sale here and there. will anyone that has both motors nearby just test this out real quick for me? thanks
n240sxfnatic
No way
E7-S14
Car: ess 14 foo!
lol no.they are of two completely different designs.
Ruff Ryder 6
have either of you tried it? i just need to know if the holes line up. forget the fact that one is a distributor and needs a cap and rotor. But that simply can't be done then i will find some other way of covering my CAS in the KA
Ruff Ryder 6
bump. anyone?
Chris28
Car: 92 s13 KA-T
I know there is someone on ka-t.org running a ka with the coilpack setup from an sr, but he is also running an sr ecu. I assume in order to run the timing from the sr ecu he is using the cas, but I never read up on it. Look around those forums and you might find your answer.
