unfrgivn »
https://forums.nicoclub.com/unfrgivn-u8387.html
Wed Jul 30, 2003 5:55 pm
Hey I got my SR running decently but it is running extremely rich... we're talking like 2-3 MPG rich. I can hear the injectors spraying like crazy so I think something is telling the computer that there is a crap load of air coming in. I changed the o2 sensor and made sure that there were no vaccum leaks, and the only possible leak would be where the intake hose goes into the turbo inlet b/c the temporary hose I made is pretty shady. I don't feel a leak around that, but it's a possibility. There is no leak anywhere else and all vaccum hoses are connected or blocked off where appropriate.
While driving around the block, my car was slugish, backfired really loud and then died b/c the engine was flooded. What all should I try before I go spending money on expensive parts. The MAFS could always be busted, but that's expensive to replace. I'm pretty sure I extended the wires to the MAFS correctly and have the plug in correctly. I could always try disconnecting the mafs and see if it changes anything. Anything else besides that to try? Any other sensors or wiring to check?
By the battery my o2 sensor (brown wire) is connected to the brown wire on the ka plug. I believe that is a 12v power source according to some other threads, but is that true?
Any ideas/suggestions are appreciated!
