I was pulling out of a parking lot today and, i am just driving normal, shift into second, the car boggs out and dies. i start it up and it runs fine. i got to school with no problems( 25miles). coming home i was just driving along in 4th gear and it boggs out and dies, go to start it and it barely starts and then boggs out, it do this like 3 more times and then finally it starts up and i drive off. and then less than a mile away it does it again another 3-4 times. i am stilling hitting full boost, i got on it after it happened to see if i had a leak and i hit 10psi.
recently i changed the spark plugs, with NGK BKR7E gaped to .032mm. and i replace the sparkplug gaskets, becasue there was oil over each plug. my car burned off the oil.
and as i said before i am just driving normal, no hard acceleration, and the problem isnt consistent.
info on my car1990 s13, redtop sr, walbro 255, stock t25 making 10psi, stock injectors, no cat, hpi fmic, ssqv non recirc.
any help would be great
