sr boggin alittle when driving
armyandy13
Car: 240sx
so my sr is currently boggin down everyonce and awhile while driving. mostly when cruisin at whatever speed it all of a sudden bog a little. and just before when i came to a stop parking my car i had it idling and it bogged a little. itwas steady 700 rpm for a couple seconds then almost stalled, but came back up. oh and the second to last turn i took coming home i was comin quick around it and i guess it must have bogged cause my power steering started fighting me cause the wasnt enough power. anyone else got probs like this.
beerking21
Car: '92 240sx
I had that sort of problem when I first got my SR, my intake was moving around to much and it caused my MAF sensor to get knocked around causing my sensor to malfunction....its an idea?
armyandy13
Car: 240sx
hum that makes sense, i know my maf isnt as secure as it could be. i just hope i havent screwed up the sensor perminantly.
beerking21
Car: '92 240sx
Probably not, just take the sensor out and if any of the connectors are bent, like mine were, then just re-adjust them, once I found this problem out the boggin' never returned. I secured my intake to my cold pipe with zip ties to keep it from moving around, hope this helps out
S13FASTBACKSR
Car: '92 Fastback SR powered
by bogging down you mean the idle goes down to low? your idle shouldnt drop when you are cruising at any given speed..only when you let off of the gas pedal or press in on the clutch pedal...this could be your bov spring needing to be tightened or your bov itself may need to be recirculated...are there any other symptoms?
