SR blown head gasket..
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
HOw bad is it to have a blown head gasket? Does the head needs to be rebuild? Help....thx
Hijacker
Car: '92 240sx Convertible
'94 F-150
the head parts and bits probably don't need to be replaced, but if the car overheated, the head is more than likely warped. In that case, a machine shop will have to mill it back to flat. Also, i would check the block for any warpage and if it's warped, have that milled as well.
BomexS13
'00 Toyota Celica
tenkawa_akito wrote:the head parts and bits probably don't need to be replaced, but if the car overheated, the head is more than likely warped. In that case, a machine shop will have to mill it back to flat. Also, i would check the block for any warpage and if it's warped, have that milled as well.
Thanks for the reply. Guy said that it over heated so I'm going to have them check for both head and block if its needs to be milled.
Does anybody know where I can do this in around So Cali? Thanks.
ride4lame
BomexS13 wrote:Thanks for the reply. Guy said that it over heated so I'm going to have them check for both head and block if its needs to be milled.
just look in the phonebook for a machine shop that will do automotive work
The Mic
Car: 3Z Wmb
Replacing the head gasket is a bit of work, and if you blew the gasket from heat you may have warped the head. You may need to get the head machined or get a new one. This can be the price of a different engine if you get it done at a shop. You could still drive your car like this but dont expect to get much more life out of the engine. If you wanted to do a swap now is the time to sit down and make a choice.
I also know of a couple places in La Habra.
BomexS13
'00 Toyota Celica
S13GUY wrote:Replacing the head gasket is a bit of work, and if you blew the gasket from heat you may have warped the head. You may need to get the head machined or get a new one. This can be the price of a different engine if you get it done at a shop. You could still drive your car like this but dont expect to get much more life out of the engine. If you wanted to do a swap now is the time to sit down and make a choice.
By any chance you can give me some info about the shop? Email it to me, [email protected]
Does having a blown head gasket affect the block as well? What kind of cleaner should I used to take out the remaining gasket residue thats stiil on the block/head? Thanks
The Mic
Car: 3Z Wmb
BomexS13 wrote:By any chance you can give me some info about the shop? Email it to me, [email protected]
check your email
BomexS13 wrote:Does having a blown head gasket affect the block as well?
It might have, you have to have the head checked.
BomexS13 wrote: What kind of cleaner should I used to take out the remaining gasket residue thats stiil on the block/head? Thanks
Go to your local autoparts store and ask, they should have some.
