SR:bad alt? fried alt. wire!!
zrowkewl
Car: 1989 nissan 240sx
ok so my sr would cut out sometimes,but i ignored it like a moron.yesterday it was real bad.cut out as in...it would just kinda not go anywhere..(batt. light was on) and it just had no juice (wipers slowed down)..i pop my hood today and the main wire to alt is DONE! just fried right off...thats why my car would just die..running off straight batt. is this from alt frying it up?? or too much amperage going through that wire? im very confused.alt. fuse is unharmed..but the wire was burnt competely off..and so was the bolt on the back of alt connecting the wire..
any ideas or tips would be grreat.thanks in advance
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Check the diodes in the alt. with a diode testing mult-meter.
zrowkewl
ill add that to the list.but if diodes are bad(failed) that would cause that wire to burn p like that? or that would cause too much amperage to come through that wire??
CSUPUEBLOTIM
If the diode didn't reverse bias it could send to many amps through the wire and cause it go get hot and melt or whatnot. Are your terminals clean and the wire is clear of excessive direct heat?
zrowkewl
oh ok.thanks for clearing that up.yes the terminals are just fine.could i pick up a diode tester at a parts tore??
S13NismoStyle
Car: 1993 Nissan 240sx Fb
I had that exact problem with my sr alternator and im willing to bet its going to be your diodes. All of mine had gone bad and i was frying power wires. Im not sure about you, but around where i live there in a guy who rebuilds alternators. I had him rebuild mine for like 75 dollars. just be sure to tell them what kind of alternator it is, they can usually get parts for it.
CSUPUEBLOTIM
You could either get it rebuilt or try finding/pricing a new diode board.
zrowkewl
yeah im just going to replace the alternator,cut the burnt peice of wire,and strip it back to a clean peice and wire that up to the new alt. is the 92 ka24de alt interchangeable with the s13 blacktop sr??
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
You might as well just upgrade that wire while you're at it. Beef up the alternator wire and the 2 other wires for the Big 3 and you should be happier.
zrowkewl
cut burnt peice off.stripped new piece and connected to new alt.car runs great.wire has not burnt up,batt light has stayed off...thanks guys.
