moso wrote:first i would check out the swap guides sticked at the top of the technical forum and the tech page articles. the clutch pedal out of a s13 will not work in a s14 or s15 as far as i know the mounts are different. you will need a new one, as well as a brake pedal if you want to do it right. the motor will bolt right up to the stock mounts in the 96, i beleive you need a trans crossmember for the 96 as its not the same as the s13 or the 96 auto. the wiring you will need to change arround, if your not good there are professionals that can do it for you like wiring specialties.
Do you have any idea what you are talking about? If you don't know what you are talking about quit steering people in the wrong direction and don't post at all.
As far as 5 speed stuff the clutch pedal will work but you will have to space it out from the firewall. Just use some washers and space it until the top bolt lines up(not hard at all). Since you are on a budget you can simply take a dremel and trim the auto brake pedal down. This will perfectly fine I did both of these to my car and it fits perfect. I am 100% positive on those 2 parts.
The rest of this I am pretty sure on but you will want to double check.
I have not tried but I am pretty sure that the s13 trans crossmember will work in the s14. The wiring harness will have to be modified to make it work or a new one purchased. You will also need to do something about a driveshaft either custom or a new front half for your s14 one. You have lots of research to do good luck!
