titotonto »
https://forums.nicoclub.com/titotonto-u3454.html
Mon Mar 10, 2003 6:22 am
What I ended up doing, was to trace each wire and write down what everything goes to. Most people you ask don't know crap and all they can tell you is to look at this website or this other one. In reality its better if you take the time and figure everything out yourself.
As per the alternator wiring I can email you what I did tomorrow cause I don't have the paper with me. Off the top of my head I know my sr alternator output was a big white wire which plugged into the large two prong plug beneath the main fuse box (by the battery), my ka had a two prong wire going to it, while the sr only had a one wire. No problem there its just that the sr alternator ground was routed to the engine block. Also, the alternator must have some type of wire for excitation of the field (inside the alternator) I dont remember the color, but I can get it later.
