JimLecesse »
https://forums.nicoclub.com/jimlecesse-u6791.html
Sun Apr 24, 2005 4:12 pm
I'm in the process of rewiring my SR. I have a brand new SR harness (from Courtesy Nissan) as well as a KA transmission/alt/starter subharness from a parts car.
As far as the subharness goes, I think I have everything hooked up correctly.
There is one wire coming from the SR alternator. Its white w/ a red stripe, (thin gauge wire) I need to know where this wire goes. It appears to run into a connector, which also contains three yellow wires, three green wires, and a blank unused pin. This connector plugs in near the fuse box.
The 6 yellow/green wires that come from this connector don't go anywhere, it appears that they've been cut. Should these wires lead somewhere, or are they unnecessary?
Should I just plug in the connector and wrap up the unused wires?
*EDIT - I just read this post and got so confused I feel a little sick, if any of this doesn't make sense please let me know and I'll try to clear it up, I can take pics also. thanks for your help!
Modified by JimLecesse at 3:32 AM 4/25/2005
