I have a
blueballa wrote:
isnt not having to convert your lines the main point of CodyAce's brackets? it allows you to keep your stock dohc compressor. so i dont think you need to convert any lines man.
anyways, what kind of compressor are you using? the stock sr one or one from the dohc?
Compare the stock KA compressor to the sr -- the sr is smaller and a hella of lot lighter. Mainly due to the fact the KA was and is a truck engine. Not to mention the funky looking piping that you have to deal with on the ka lines. The cheapest way to do it if you can vac and recharge your system would be to get lines made for 75 bucks and call it a day. Or if you want to use Cody's plates then have at it. After all the research, I found the sr compressor is smaller, lighter, faster and cools better than the KA compressor that I had and you do not have to deal with the huge pipe thing sitting on the top of the KA compressor..
Modified by shift_SRDETuser at 7:16 PM 8/10/2009
