KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sat Jul 08, 2006 1:41 pm
To add to this...
It's high impedence...impotence is when you can't get your "rod" up.
Also, as stated above, replace the o-rings, but make sure you lubricate them so they don't tear when going in. I always use a glob of wheel bearing grease and have no problems. Any grease that gets into the cylinder burns out immediately, so no ill-effects.
